Old 10-29-2006   #1
ZR1ROB
Default Do you feel a "kick" when the secondaries activate?
I have a '92 that gives a little "jolt" when the key is on and RPM's hit around 3000 (tach reading). I suspect that the actuators are jerking open at that point. It's easily noticable when it happens.
On my '91, there's nothing noticable when the key is on and rpms come up anywhere. The car does have the serious power band of a zr1. But it doesnt exhibit the same "jolt" as the '92.
Do you feel the "jolt" or does your car smoothly transition into the secondary action?
ZR1ROB is offline   Reply With Quote
Old 10-30-2006   #2
Default Re: Do you feel a "kick" when the secondaries activate?
My 91 did when I got it... I removed and replaced the actuators cleaned and lubed the linkage.. they were on upside down and binding at about 60% open than would pop open to 100%.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-22-2006   #3
ajaxajax2000
ajaxajax2000's Avatar
I also have a '92 and I never felt any specific secondary engagement jolt(other than the mere increase in power). I'll check closer come spring, though.
Peter
ajaxajax2000 is offline   Reply With Quote
Old 11-23-2006   #4
jonszr1
jonszr1's Avatar
have you done a vacume ck on the secondary system. When i had a 3sec leak( pump to15takes 3 sec to go to 0) It felt just as your discribing. Fixed my leak now its seamless
