Old 08-20-2014   #1
gen2rt
Default Bad injectors or vacuum leak?
I have a 1994, 19,000 miles, haibeck intake & port polish, headers.
Car suddenly has no bottom end, meaning bad stumble/dies at idle, when I get into it everything is fine. Since the car sits a lot my initial thought was bad primary injector(s). After searching forum, vacuum leak also looks to be a possibility. Looking for input from anyone experiencing something similar.
Thanks,
Jack
gen2rt is offline   Reply With Quote
Old 08-20-2014   #2
Kevin
Kevin's Avatar
Default Re: Bad injectors or vacuum leak?
with the miles I'm going to say injectors. a vac leak will cause the car to fall flat high in the rpm band
Old 08-20-2014   #3
make sure your MAP sensors are connected
Old 08-20-2014   #4
Ccmano
Ccmano's Avatar
I'm with Lee... fuel pump possible too. My money is on the MAP sensor tho.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-20-2014   #5
I was having an issue at cruise......had rotted rubber on the MAP sensor that was not visible until close inspection....Fuel Pressure Regulator too
Old 08-20-2014   #6
Demps
Demps's Avatar
Jack,
Where are you located?
Ted
Old 08-20-2014   #7
tccrab
tccrab's Avatar
Map sensor hose is first guess.
Does it smoke on startup?
Second guess is fueling, either fuel pumps or filter.
Since it's a '94, injectors aren't as likely to be at fault as if it were a '90 or '91.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 08-22-2014   #8
gen2rt
Thanks for the responses. I'll try the MAP sensor hose/connections. The ZR is parked in Colorado, I mostly live in Reno though. I'll hold off ordering new injectors and will dig into the MAP sensors when I get back to CO (in a couple months). I hope that's what it is, would rather not get into a plenum pull if I don't need to.
If the MAP sensor is ruled out, I'll start looking at the other suggestions.
I'll post back here what I find for reference.
Jack
Reno, NV
Old 08-22-2014   #9
Jack
Jack,
I'll be in Denver next weekend. Where is it in CO. Darby and I can check it out.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-23-2014   #10
gen2rt
Xfire,
PM sent.
thanks,
Jack
Reno, NV
