08-12-2014 | #1 |
Show me your audio setups
My stereo doesn't work and I have decided to pull the trigger and dump the stock radio in favor of a newer variety.
With so many options out there I wanted to see what most of you guys do. Do you take advantage of the cubby holes behind the seats for amps? Do the stock amp/speakers work with aftermarket headunits? |
08-12-2014 | #2 | |
Re: Show me your audio setups
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
08-12-2014 | #3 | |
Yes, I have connected Aftermarket headunits to the OEM Bose amps and did the reverse.. OEM headunit to aftermarket amps. My set-up also requires cutting the bezel System components: 2 Arc Audio KS300.4 Amps 2 Elemental Designs EU700 (rear woofers) CDT: TW25 tweeters CL-4 midrange and EF-6 Midbass (Front stage) Headunit and control: Nexus 7 Behringer UCA-202 USB DAC Directed DMHD1000 HD Tuner SDR FM tuner (not really using this) Phoenix Gold PLD-1 USB-ALDL Cable for ALDLDroid on Nexus (Custom Volume and Balance Controls in Bezel) Mini-Box Power supply for USB Hub and Nexus 7
08-12-2014 | #4 |
08-12-2014 | #5 |
08-13-2014 | #6 |
Do all double din radios require modification of the center console panel?
08-13-2014 | #7 | |
The App Radio is still in great shape if you are interested
08-13-2014 | #8 | |
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
