Old 08-11-2014   #1
louispf
louispf's Avatar
Default A/C shut off
This sounds a little crazy but my a/c works fine @ idle but when brought up to 1500 to 2000 rpms the light on the head blinks and goes into default. We pulled the fuses to reset and the a/c goes cold again @ idle. Any thoughts?
louispf is offline   Reply With Quote
Old 08-11-2014   #2
Default Re: A/C shut off
Did you pull any codes??
Normally flashing LED is a low freon indication
Old 08-11-2014   #3
louispf
louispf's Avatar
Freon is fine and line pressures are where they are supposed to be. We did not pull any codes. When the light flashed on the head unit to reset it there are 2 fuses you pull for 15 seconds and that resets the system. At idle the system operates as it should.
Old 08-12-2014   #4
Could be the AC programmer above the acceloraor pedal on the firewall. However without running the code or the tests in the FSM (Factory Service manual) eveything is a WAG.
Old 08-13-2014   #5
louispf
louispf's Avatar
Thanks, we figured that out. Found it in the FSM. I'm meeting up w/ TomTom tonight and we are going to pull the codes.
Is the AC programmer ZR1 specific? Thanks....
Old 08-13-2014   #6
Well ok then. Good luck with your quest im sure TomTom can figure it out. GC
