Old 08-02-2014   #1
5ABI VT
Default Pulling the plenum / IH Some pics !!
Thought I would just make a thread here with some pics. Will be sending the plenum and IH out for porting and a re-tune for the chip. Will be removing the secondaries as well as having the coolant plugged for the plenum/TB.
I just went over a few old threads and posts and theres a ton of info on this site so figuring things out should be pretty easy. One thing I wanted to say was I have a noticeable amount of oil in the plenum.. Ill take better pics in the light tomorrow.
pics for my own reference if needed..
Parts starting to pile up
Had to loosen this fuel.. connection? to get to this bolt. I also removed the fuel rail cap and tried to relieve pressure... there was no fuel to come out at all. bad thing?
Getting there..
Noticeable amount pooled up at the back. Will be installing catch can(s) before reassembly. Will take some pics in daylight tomorrow.
Old 08-02-2014   #2
5ABI VT
Default Re: Pulling the plenum / IH Some pics !!
Oil in the plenum..
Old 08-02-2014   #3
5ABI VT
Not sure if I read anything about it when removing the secondary vacuum system.. there was a connection to the bottom of the plenum. Does this need to be plugged or .. ?
Old 08-02-2014   #4
You have a 94. Are you talking about the Differential Pressure Sensor under the plenum?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-02-2014   #5
tf95ZR1
tf95ZR1's Avatar
VERY CLEAN!
Engine & workbench
Who's doing your porting?
I also had a puddle of oil in my airhorn.
Old 08-02-2014   #6
PhillipsLT5
PhillipsLT5's Avatar
Originally Posted by tf95ZR1 View Post
VERY CLEAN!
Engine & workbench
I know, you better start cleaning, LOL
Really, Very Nice!
Old 08-02-2014   #7
mike100
about par for the course on the plenum oil.
Old 08-02-2014   #8
5ABI VT
That sounds like it. Is it for the secondary vaccum ?
I'm having Pete do the port work.
Thx I just finished painting this half of the garage and putting up the cabinets and work benches up/together along with the lighting. It's why it took so long to start the pull and it feels so nice to have a better place to work
I didn't have any oil in the air horn maybe just faint residue. The one grommet on the passenger side wasn't fully seated inside the injector housing and not sure if a slight leak would affect much .
Hoping to pull the injector housings tonight !
Old 08-02-2014   #9
Yes. Its the Differential MAP sensor. Tells the ECM there's enough pressure differential for the secondaries to activate. Once the secondaries are un-installed, Pete will make the necessary calibration change bypassing it.
That sensor is located under the ECM in earlier model years.
Old 08-02-2014   #10
5ABI VT
Makes sense now thanks !
This is what my VW needs lol!
