Old 07-20-2014   #1
Pumpman
Default AC question
My AC stopped working. I disconnected the Neg. Battery cable for a couple minutes and it re-set. Working fine now. First time this has happened. Should I be looking deeper for a root cause? Is some component on the way out?
Pumpman is offline   Reply With Quote
Old 07-20-2014   #2
Schrade
Default Re: AC question
What do you mean by 'it re-set'?
Was there an A/C Controller code that read out, and is gone now? Or did the function 'restore'?
If you did not have a Hardcode DTC, then the time factor shutdown-restart WITHOUT DISCONNECTING THE BATTERY, could have done the same thing???
Old 07-20-2014   #3
Kevin
Kevin's Avatar
if you end up needing a new compressor i suggest discountacparts.com
Old 07-20-2014   #4
KILLSHOTS
Interesting. One thing I've noticed - both with my '90 Z and my old '87 convertible - is that the A/C always comes on full-blast when I start the car the first time after a battery disconnect. Not sure if the two issues are related somehow. Good luck.
Old 07-20-2014   #5
gbrtng
gbrtng's Avatar
Probably marginally low on freon - watch for a blinking LED in the control panel which is the tip-off.
Old 07-20-2014   #6
Pumpman
By Re-set I assume there was some kind of programing reset in the ECM. I do not have a code reader.
Old 07-20-2014   #7
Pumpman
I believe that in 91 the AC refrigerant is still R12. Fortunately I stocked up on R12 back when it was about to be banned as my 73 uses R12 and I didnt want to make a costly conversion.
Old 07-20-2014   #8
gbrtng
gbrtng's Avatar
with an automatic AC control:
* Disconnect the small/rear connector on the liquid line to enable the fans full time. The
fans run continuously as soon as the engine starts - you need air flow thru the cooling
stack for the AC system to operate efficiently.
* if the system is really low on freon, the AC control will flash an LED, so you disconnect
the battery for a minute to clear error codes. Apparently the compressor may not run
if one or more codes are stored.
* connect a can of freon to the dryer(?) and completely open the can valve - freon will now be going into the system
at about 100 PSI - dunking the can in hot water will help speed the process. Remember to purge the
hose before connecting to the dryer.
* connect the battery and start the engine - the AC will be in the auto mode by default - set the blower speed
to 10 and the temp to 60.
* the compressor should be cycling or running full time by now. If cycling, the "on" time should increase to 100%.
If the freon level is too low, the system will set a code again and the compressor may not run at all, so you
add more freon and start over at step one.
* measure vent temperature - one can brought the temp down to 48 degrees with outside temp of 82.
This was with a system low enough to set a code and the compressor would not run.
TGF
Old 07-20-2014   #9
Pumpman
Thank-you for the detail. Was very helpful.
Old 07-20-2014   #10
diamond zr1
I was always told NOT to add liquid/by turning the can upside down/ to the system/mabe a a/c expert can chip in/joe
diamond zr1 is offline   Reply With Quote
