07-17-2014 | #1 |
New to ZR-1 Removed Sec Vac system and now problem
Thank god I found this site a few weeks ago. I decided that the secondary vac system had to go so I ordered gaskets from jerry. Removed all vac junk under the plenum, pinned the secondaries open, replaced all nec vac lines, and installed chip from Haibeck. Started the car and it started up and fell down to idle and died. Check engine light is on now and car will idle sometimes but has a hesitation at idle. What should I check???? Again NO emissions/secondary junk is on the car but did leave everything connected electrically wise.
Only modifications are headers, full exhaust, no emissions and now Haibeck chip. I did start the car without the map sensor plugged in had an oops moment wasn't sure if that has caused some code I need to dump or not Any of you zr experts imput would be appreciated |
07-17-2014 | #2 |
Re: New to ZR-1 Removed Sec Vac system and now problem
Welcome my brother.....
A couple of things come to mind to make sure are done. 1. Ensure electrical connector to vacuum solenoid is still connected under plenum. Vacuum lines do not but electrical connector does. 2. Ensure map sensor under ECM stilll has a vacuum source and electrical connection in tack. Might be 1990 year only. 3. Power Key must remain ON the power mode at all times. Hope this helps.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
07-17-2014 | #3 |
All that checks out except for the sensor under the ecm. I thought it was suppose to be left without a vacuum line but if it needs one Ill surely put it on.
07-18-2014 | #4 | |
07-18-2014 | #5 |
That is what I thought and plugged mine and I had issues. Just try it and see if it works.
07-18-2014 | #6 |
I gather you chip is not done,
What ever the case put a vacuum hose from vacuum pump to MAP sensor Under ECM if you just connect to a Vacuum source at the engine will Not work at WOT and have the Sensor under plenum connected Pete
07-19-2014 | #7 |
Thanks for input, Car is fixed. As I suspected it was the map sensor. Replaced and everythings A ok now. Thanks fellas
