Old 07-17-2014   #1
emmvette
emmvette's Avatar
Default Want a magnetic oil drain plug
I can not find a magnetic drain plug looking at Jerry's G, White R., or Marc H's sites.
I saw a thread from 2009 with a MagDana link, but they don't appear to be around any longer - didn't last a year.
Does anybody have a source or recommendation?
emmvette is offline   Reply With Quote
Old 07-17-2014   #2
WVZR-1
Default Re: Want a magnetic oil drain plug
Here's one on eBay with a very similar correct seal:
http://www.ebay.com/itm/Magnetic-Oil...-/350396106072
If you find someone that sells "The DIMPLE" brand drain plugs they would have it also. I believe the brand originated in the UK. JJ of MagDana I thought carried that product to a new business but I haven't communicated with him for maybe 4 years.
There are motorcycle shops that do "The DIMPLE" also but you need to watch the 5/8-18 from them, it's a very old different style HD drain plug. I've a friend that has a couple of them
Try some searches using "The DIMPLE" branding - that might work also. Haven't tried.
Here's a link to maybe a "distributors page" for The DIMPLE:
http://www.drainplugmagnets.com/authorizeddealers.php
The eBay offering is really inexpensive.
You might stumble across a couple of my posts in your searches and I did mention that the OE/GM plug has a sufficient "counter-bore" that you could insert a magnet of your choice. As strong as you can find!
Old 07-17-2014   #3
efnfast
I think the issue is, most of the wear items in the engine are not magnetic. Cam chain's and cams may be the exception.
efnfast is online now   Reply With Quote
Old 07-17-2014   #4
emmvette
emmvette's Avatar
I hadn't thought of that. Maybe its not helpful.
