Old 07-15-2014   #1
65ZR1
Default Tuning with Tunerpro
Im a complete noob when it comes to tuning but I would like to learn. Can anyone recommend any sites to learn the basics and get me started? I downloaded tunerpro and the 93-95 definition file. Where can I get a bin file so that I can start exploring the program?
Thanks!
65ZR1 is offline   Reply With Quote
Old 07-16-2014   #2
1990 quasar blue
Default Re: Tuning with Tunerpro
http://m.thirdgen.org/techboard/forumdisplay.php?f=16
Old 07-16-2014   #3
65ZR1
Thanks, Ive been reading for a few hours. Good stuff.
Any recommendations for hardware and software? Ive been looking at tunerpro, moates and innovate for the wideband oxygen sensor.
Any idea where I can get a stock 94 bin?
Old 07-16-2014   #4
Definitely go to 3rd Gen and read the stickies. Take a look at a presentation I did for the Gathering this May also.
http://www.zr1.net/forum/showthread.php?t=23027
Old 07-18-2014   #5
65ZR1
Great presentation! Thanks for the info. Any recommendations for hardware or software?
Old 07-18-2014   #6
My recommendations would be for the software/hardware in the presentation.
=Jeff= has created an adx file for Android tablets u can use to datalog.
You need a
1. chip burner/reader
2. Scan tool/datalogger
3. Bin editor w correct Def Files.
4. Lots of time and gas
5. For WOT, YOU'll need a Wide Band O2 (Innovate, Zeitronix ZT-2, DYNAMIC EFI TT-1 WB)
Old 07-18-2014   #7
Here is what I am using:
  1. Moates Burn1
  2. Tunerpro RT
  3. ALDLDroid
  4. VETuner
Burn1 to burn my PROMs
Tunerpro RT for making changes
ALDLDroid (or Tunerpro) for Datalogging they both use the SAME ADX file
VETuner for auto adjusting the VE tables based on the BIN file and the datalog
Old 07-18-2014   #8
65ZR1
You need a
I see you mention the Moates Apu1 and the Ostrich 2.0 Doesn't the APU1 also do emulation or does the ostrich 2.0 do a better job.
Would this be good?
Moates APU1
Moates G1 chip adapter
TunerPro
Innovate LC-2 wideband controller
Anything else?
Old 07-18-2014   #9
65ZR1
  1. Moates Burn1
  2. Tunerpro RT
  3. ALDLDroid
  4. VETuner
Any preference over ALDLDroid or Tunerpro Jeff? Tunerpro will datalog and edit in one package. Does this keep things simpler?
Old 07-18-2014   #10
Would this be good?
Moates APU1
TunerPro
Anything else?
Those are fine. The APU1 is an All Purpose Unit. So it reads and writes chips, also does emulation. Ostrich is just an emulator which was fine for me since I already had chip read/burn equipment.
