Old 07-13-2014   #1
tf95ZR1
tf95ZR1's Avatar
Default Turn Signal Flasher
Where exactly is the darn turn signal flasher located?
I tried to finish up a project for a Route 66 car show tomorrow,
(today) but I can't find the flasher, I'm tired, and getting nowhere.
I removed the drivers side hush panel and looked underneath
the dash. The FSM says it's to the left of the steering column
under the dash. It is round and secured by a clip attached to
a block holding 3 other relays. Nice schematic-no help.
Electrical is not my favorite and I hate being upside down under the dash.
There is a sea of wires, connectors, inline fuses, and harnesses under there.
Is it forward towards the firewall? Up high by the top of the dash
or just above the hush panel?
I can't believe I can't find it! Any suggestions?
TIA (NOT a Transient Ischemic Attack!)
Old 07-13-2014   #2
WVZR-1
Default Re: Turn Signal Flasher
Hey Ted,
If it's not been moved and left hanging try reaching up at the clutch pedal pivot area. It should be up and left of pedal pivot point. I believe it's "outboard" of the relays towards kick-panel if it's not been moved! It's not a part of the relay bracket and it's likely "loose" and just been stuffed up there. What leads you to believe you need flasher? A bad flasher will generally click once with each move of the TS lever. Try using the turn lever a couple times and listen for it. Maybe!
Old 07-13-2014   #3
c4koh
c4koh's Avatar
When my flasher went bad, the turn signals would just not flash (they'd just be on permanently, no blinking). Here is where mine was (this was on my 1991, not sure if other years are different, though I'd expect not...)
c4koh is offline   Reply With Quote
Old 07-13-2014   #4
Nice clean photo of drivers side wiring...thanks
Note the hush panel light wiring dangling down to the left and Assembly Line Diagnostic Link (ALDL) Connector dangling down to the right (the two items connected to the Drivers Side hush panel).
Old 07-13-2014   #5
tf95ZR1
tf95ZR1's Avatar
Wow, does that look CLEAN compared to my mass of wires! Either some-
one meticulous bundled your wires, or a bomb went off under my dash.
Thanks for the photo! Tonight when its cooler, I'll look for it again.
102 deg today and HUMID. Yuck! But Route 66 was fun, even if
instead of the Z I took my Expedition....
Sorry, lousy iPhone 4 camera
Old 07-14-2014   #6
Locobob
Let me guess.... LED turn signal upgrade?
Robert
Old 07-14-2014   #7
tf95ZR1
tf95ZR1's Avatar
Yup, and I moved the tail lights out
so they are flush and installed sequential
turn signal electronics. I'll see if I like the look.
I hope so after all this work!
WHY CAN'T WE JUST BE SATISFIED?
Old 07-14-2014   #8
902066
so they are flush. I'll see if I like
the look. I hope so after all this work!
How and what parts did you use to move the lenses out? I would like to do the same if its not more trouble than its worth. Thanks.
902066 is offline   Reply With Quote
Old 07-15-2014   #9
tf95ZR1
tf95ZR1's Avatar
I didn't just move the lenses out, I moved the entire light enclosure outwards and I custom cut some rubber perimeter gaskets. I saw an old post where someone just used either a thicker gasket or layered gaskets: Not what I wanted to do, plus the enclosure is a wider diameter when flush, so what about the space?
Old 07-15-2014   #10
USAZR1
USAZR1's Avatar
Got any photos of the finished product,Ted? Sounds like a cool mod.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
