Old 07-07-2014   #1
92whiteZ
Default A/C gauge readings
I thumbed through the Service Manual but didnt see what i was looking for.
What should the high & low side gauges read when the system is fully charged?
this is for a 1992 with a R12 system that is all original.
many thanks!
92whiteZ is offline   Reply With Quote
Old 07-07-2014   #2
Default Re: A/C gauge readings
What is the Ambient Temperature outside? Humidity?
This should help
Old 07-08-2014   #3
cvette98pacecar
Keep in mind that your pressure is actually going to be a little higher than what the PT chart says unless you have a big box fan moving air across your condenser.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 07-08-2014   #4
92whiteZ
Thank you everyone and don't know how i missed that chart.
Temps tend to be high 70's/low 80's, humidity around 45-50%. will make note of higher temps without a fan blowing across the condenser.
as always this group is top notch and extremely helpful.
big thanks to all.
Old 07-08-2014   #5
Also looking at the PT chart you can see why R134a will put a bigger drag on the motor than R12
Old 07-08-2014   #6
Excellent Information Jeff....thanks
This should help
