Old 07-04-2014   #1
Z06scentair
Z06scentair's Avatar
Default Oil smoke
Just got back in from Japan yesterday and decided to get the car out this morning.
Backed in out of the garage and let it idle for ten minutes before going for a ride. The car has not been started in a month.
Here is where the question comes in. When I got in the car to back up in the driveway, I touched the gas and a large puff of oil smoke appeared to come from both tailpipes. I revved the motor a few times and the smoke was gone. Left for my drive and everything seemed fine.
What could have been the root cause of the oil smoke?
Z06scentair is offline   Reply With Quote
Old 07-04-2014   #2
Default Re: Oil smoke
if you ever pull the plenum you will see its coated on the inside with oil, might have pooled due to sitting....and then burnt off at startup
Old 07-04-2014   #3
Z06scentair
Yeah that's possible.
Old 07-04-2014   #4
mike100
The 1990 models don't have the viton (rubber) valve seals so they are known to puff a bit on hard accel. If you have a '90, totally explainable.
