Ok guys. Car runs fine but last year at The Woodward Cruise, car began to overheat. We were c r a w l i n g in traffic. 1hr to go a mile. Decided to either replace with Fluidyne or clean it. What'dya guys think? Love it or list it?
![]() Join Date: Mar 2007
looks like you had a dead cat or maybe a small dog....like a pug, stuck to the front of that thing
![]() Join Date: Feb 2011
Get a radiator fin comb and go to town. That thing will cool fine when it isn't 40% plugged up.
Still, idling on a 90 degree day in traffic with the a/c on is going to run hot, especially if you are on black pavement (vs concrete road). The super heated road surface air, the oil cooler heat exchange, and a/c condensor heat can be a bit much. With reprogrammed fans and the ability to turn off the a/c, the stocker will work well enough. I think it may be possible to never have to turn of the a/c with one of those 4 row aftermarket units, but I can't say for sure. |
Mike,
Not running A/C at the time. With all the cars around me, I'm sure the ambient temps were quite a bit higher than what the weather was. Sort of a micro version of Global Warming. I power washed it and blew it out w compressed air as well as I could. I'm sure it will improve things considerably. Hopefully it won't take too long to go closed loop in cooler weather.
#5 | ||
Excellent and Important Thread and photos
![]() ![]() Quote:
But you already know that as it appears the before and after photos had the same fin damage ![]() The radiator I cleaned just last week before I installed a radiator Debree Screen......had one of those small plastic grocery bags sucked up between the Oil Cooler and Radiator........you want the path below the Oil Cooler and Radiator totally clean so air can move under the oil cooler and up between the oil cooler and radiator as well. It also is good to use Engine Degreaser on the Oil Cooler (and even Radiator) before you carefully use a pressure washer if oil has contaminated the fins as the oil collects the finer dust particles. See Item #3 LT5 Added Systems
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-03-2014 at 10:42 AM. |
#6 | |
That was the Aqua ZR!
Dyno,
Those pics are front and back not b4 and after.
That means you have fin damage on both sides which is unusual
#9 |
Altho I bought a fin comb, I conferred w Mr. Polatsidis today and we decided too many fins were compromised. Could be a great winter project to straighten all out but in the meantime I'm installing the Fluidyne. Much better shape and better chance of doing it one time.
#10 |
happy with my fluidyne for years in AZ, took Hib's advice, no buyer remorse
