Old 06-29-2014   #1
Default AL, you were this close....
Maybe if you ran 40psi in the tires... Now you gotta run in October and so do Kevin and BobG.
161 won the trophy for Private N/A class.
Old 06-29-2014   #2
ALZR1
Default Re: AL, you were this close....
Oh i'm going to run i n October hopefuly I'll beat that time,Mark your calenders.
AL.
ALZR1 is offline   Reply With Quote
Old 06-29-2014   #3
Gentlemen,
I guess the game is afoot! Oh it's ON.
Old 06-29-2014   #4
Gentlemen,
Looks like it! But, hey! The CPCC 1/4 mile Corvette Shootout (TBA) is likely going down the previous month. All of the above and Pete need to defend their trophy. Lots of racin' for the FBI and surrounding Zs yet this year!
BTW, were you able to run down that oil leak? Was it that low oil pressure switch that blew? It is a common problem with old brittle plastic - discovered while at WOT, apparently. (I gave up trying to get to that SOB from the side, and removed the oil filter housing to get to it at my leisure. Once I decided to remove the oil filter housing, it took under an hour from tear-down to fire up. (only broke the locking tab off two brittle Weatherpac (sp?) connectors too! (Dangit! ))
