Old 06-27-2014   #1
kengodfrey
Default Injector problems
I recently changed injectors in 1991 ZR1. Sometimes it cranks fine, runs perfect, and sometimes it sputters out black smoke, and smells like raw gas. I am assuming it is the injectors, but wanted other opinion before i pull them out and have them checked.
Thanks
kengodfrey is offline   Reply With Quote
Old 06-27-2014   #2
Schrade
Default Re: Injector problems
Maybe do static pressure test and leakdown time.
Doesn't seem likely tho', that it's a leak problem...................
Old 06-27-2014   #3
Kevin
Kevin's Avatar
what injectors did you use? What else has been done to the car recently? who did the work? Are you sure everything is connected properly
Old 06-28-2014   #4
vettn71
If you didn't flush your fuel rails during replacement it could be a bit of dirt got in an injector. Even if you did flush them it can happen
Goof luck
vettn71 is offline   Reply With Quote
Old 06-28-2014   #5
Ditto.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-28-2014   #6
Sounds like a leaking injector. As suggested, a static leak test will verify it, and if so, the injector(s) at fault can be isolated.
Install a fuel pressure gauge to the Schrader valve on the front of the passenger side fuel rail.
Turn the ignition switch to RUN, without starting the motor, just long enough for fuel pressure to stabilize.
Monitor the pressure. If all is well, pressure should hold to within a couple pounds for 10-30 minutes (mine held to 30 min). (But, in your case, it sounds like a major leak, and you may even be able to observe fuel jetting from the bad injector if the ignition switch is left in RUN long enough to look down the IH bores at all 16 injectors.)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-28-2014   #7
RICHARD TILL
Read your plugs.
Old 06-28-2014   #8
Schrade
If your lines were fouled, your INJ's might need breakdown...
What can ya' do to an injector with a hammer, a prybar, and a 16mm open end?
This:
Old 06-28-2014   #9
Karl
Karl's Avatar
Curious as to what type of injectors did you use?
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
