Old 06-23-2014   #1
Default Repair for weather stripping?
There is currently a thread about treatments for weather stripping. I was wondering if there is any repair product for weather stripping that is starting to chip and crack to avoid outright replacement. Any type of rubber caulk like material that might be smoothed into those spots to make it at least a little better before I have to replace it. My A pillar rubber is getting a bit rough.--Bob
Old 06-23-2014   #2
Default Re: Repair for weather stripping?
Maybe Black RTV until you are able to replace the stripping.
Old 06-23-2014   #3
yep, use a rubber glove and rub it into the bad area than let cure 24 hours.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-23-2014   #4
mike100
I have used RTV and some plastic newspaper sleeves coated in mold release/non-stick cooking spray. Simply close the door glass on it and let the rtv mold to the shape. The open air ones just smear it over and level it off with a rag etc.
The weather strip does have to be reasonably intact, but i have used this method to repair a slice on my C6- it came out so good you can't even tell where it is without looking closely.
Old 06-23-2014   #5
vettn71
Black weatherstrip adhesive is better. Wrap clear plastic wrap around it and tape it together. Used this on the corners of my rear hatch and it works well
vettn71 is offline   Reply With Quote
Old 06-23-2014   #6
I wondered if that wouldn't work. I'll have to try that too.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-24-2014   #7
Thanks Guys. I will try the RTV or weather strip adhesive. Hopefully I will be able to make it look a little less raggedy.--Bob
Old 06-25-2014   #8
nelson007
nelson007's Avatar
I have used 3 M strip caulk ( Black) on some of my older Vets.
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 06-26-2014   #9
Ive used black urethane but the area has to be completely silicone free.
