Old 06-22-2014   #1
vilant
Default New oil cooler lines
Just installed my new oil cooler lines from Jerry's. Could I have built my own, sure. But I'd rather spend a little more and support the very few vendors that are out there, to keep our cars running 100%. Easy job to do and Jerry sends a installation sheet too (although the one thing I would change is, once both lines are connected to the block, I would then connect them to the adapter and then to radiator. Connecting the adapter first to the radiator, then lines is almost impossible, unless you remove the radiator shroud first on a 1990). Here's some before and after pics.
[IMG][/IMG]
A big thanks to Jerry for making these available and your installation sheet made it super easy. They look great and no more leaks.
Joe
1990 Bright Red ZR-1 #2599
Old 06-22-2014   #2
USAZR1
USAZR1's Avatar
Default Re: New oil cooler lines
Looks great!
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
Old 07-11-2014   #3
Thanks for the feedback Joe. I will edit my installation procedure to reflect your suggestion.
I probably missed the shroud interference because I had cut mine for clearance when I installed the Ron Davis radiator 10+ years ago.... and just forgot about it. Getting older allows one to incorporate a new set of lame excuses!
Old 07-12-2014   #4
cvette98pacecar
Just looked at these online, You cannot buy the parts and have to do the work for that price. Thank you for everything that you do for LT5 Owners.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 07-12-2014   #5
cvette98pacecar
Just looked at these online in your store, You cannot buy the parts than have to do the work for that price. Thank you for everything that you do for LT5 owners.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
1998 Pace Car
