06-19-2014 | #1 |
treatment for weather stripping
What do you recommend for treatment on the rubber weather stripping on the top and around the windows. Mine is near perfect and I want to keep it thaT way.
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
06-19-2014 | #2 |
Re: treatment for weather stripping
Dielectric silicon grease
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
06-19-2014 | #3 |
06-19-2014 | #4 |
id of thought armorall..would that be preferred to armorall in general?
06-19-2014 | #5 |
Awesome. Learn something all the time.
06-20-2014 | #6 |
Yeah never heard of the dielectric grease for that. I use Aerospace 303..
06-20-2014 | #7 |
Interesting. But, does dust stick to it? I've always used those silicon based goops like "Black Magic" or the like.
The 3M 303 Protectant has long had rave reviews and contains SPF 40 ultraviolet protection especially for vinyl (rubber is mentioned as well) to avoid cracking, etc. I wonder how it compares to dielectric grease (which I've also heard works on rubber as well)? I judge how well it protects if after it dries and I rub it with a white cloth: is there black residue on the cloth that would indicate the rubber is oxidizing?
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 06-20-2014 at 06:47 AM. |
06-20-2014 | #8 | |
I don't know that your test is very valid but I'll assume you're talking about weeks/months from it's use. Yes/no? Last edited by WVZR-1; 06-20-2014 at 07:46 AM. |
06-20-2014 | #9 | |
That said, the reviews for the 303 stuff is very good. I believe Adam's has it available (or did at one time), and like you said, the internet has solved a lot of product availability issues! Can't say the rubbing "test" is necessarily comprehensive or conclusive. However, it is obvious that rubber that IS deteriorating in the sun becomes dull and will leave a black smudge on a finger or cloth when rubbed. It has been my experience with the silicone based stuff that the deterioration (oxidation?) I spoke of seems to stop after its use. But, is that a true evaluation of protection? I dunno. (Could be some MIL spec test(s) is/are available, if one were to dig into it a bit more. Course it would end the anecdotal speculation, but what fun would that be?? )
06-20-2014 | #10 |
Dielectric grease can be found on Amazon for a reasonable price. A little go's a long way.
It should be rubbed into the weatherstrip slowly and evenly. All side's of the weatherstrip that you can get to should be done. This takes time , but is well worth it. After a couple of weeks go back and do the weatherstrip that has been exposed to the sun and do it over again. Don't leave excess dielectric grease on the weatherstrip. Doing so will just be a waste.
