Old 05-22-2014   #1
Vetman
Vetman's Avatar
Default Injector question
Are my injectors origins for 1990 z?
Black plastic top with # 5235357
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 05-31-2014   #2
Default Re: Injector question
Actually, there are two different injectors on the 90 only engines; the primary and secondary are different. (The primary seals at the top of the injectors where the secondary seal is near the tip.)
Jon at FIC will be able to help. And, if you do have original injectors, you will want to replace the with NEW stainless steel ones (NOT "rebuilt" )
Paul
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
