Old 05-20-2014   #1
Thumbs up My experience with the Hawk HPS brake pads
I can report that the Hawk HPS brake pads were terrific during the 3 days of Tail of the Dragon, and Devil's Triangles,, 6 Gaps, and the like (i.e., the Mountain Run leading up to the BG Gathering). They really, really(!) bite quite well - never failing or fading during the entire 3 days of romping around.
As result, I no longer believe I'll be installing a brake upgrade (C5 Z06 or the like) after all: the Mountain Run showed me that. Apparently there is no need, based on my experience with the Hawks - at least not for my style of driving: I don't track the car and only do a little straight line stuff with just a few trips to the hill country around Galena and Wisconsin.
They DO dust a bit, but apparently only when called upon for driving of the likes we did on the 3-day run. However, the dust cleans right off w/o any special soap or scrubbing required. And, after washing the dust off, there was NO noticeable dusting resulting from the 380 mile trip home, i.e., normal highway driving. I'd have to conclude the C6 Z06 brake upgrade that Dom completed - or even the C5 Z upgrade would, in my case, be beyond anything I have required the stock ZR-1 brakes to do to date.
Of course, your requirements may differ.
Paul
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-20-2014   #2
Gunny
Gunny's Avatar
Default Re: My experience with the Hawk HPS brake pads
thanks for the good report, Paul ... I've been using PFC (Performance Friction) pads for 10 years or so but am interested in trying the Hawk the next time around. When I first bought PFC from Autozone the pads came with a lifetime warranty ... return the used, worn out pads and get a new box, absolutely no charge. I think I got 2-3 sets in this manner until Autozone pulled the plug with this offer and no longer honored that warranty ... too many enthusiasts were buying on Thursday, going to the road track on the weekend and coming back on Monday with worn out pads.
George Jones
Founding Member #14
www.zrwon.com
Old 05-20-2014   #3
You never have enough brake. With the Z06 brakes u also need to commit to compatible/larger wheels. Different strokes...
I'm using Hawk Ceramics
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-20-2014   #4
efnfast
Paul, just the pad change? No rotors or anything? SS lines? -Steve
Old 05-20-2014   #5
mike100
The biggest advantage to the C5 brake conversion is the cheaper brake pads, rotors, and calipers. The next thing is the thicker rotors and larger pads for a thermal advantage, but as far as pedal feel the J55 is a little tighter since the caliper mounting is more precise.
The only reason I did mine was because I had a toasted J55 caliper and when I bought the car it had almost the entire conversion kit in a box incl A-Molds so I was able to follow through without spending too much. It is still a lot of work chasing down every last detail like the GTO spare tire, adapter brackets, braided lines, not to mention the GM parts... it is a $1000 task if you buy good rotors.
Old 05-20-2014   #6
Nope. Nothing against rotor changes, but mine were in very good shape to begin with, and as such all I did was follow the usual seasoning routine outlined in the THIS ARTICLE to which I can attest to its validity over several vehicles and many sets of pads on sedans, my trucks and Jeeps, and now Vettes...
Even with some minor ripples on the disc surface (other vehicles) I haven't turned a disc on any vehicle in over 15 years. If they're that badly grooved or beveled (calipers sprung), or have hard spots (mistakenly referred to as "warped"), I replace them (and sprung calipers) with new. All that said, I don't road track my car aside from what we did last week. If I did, then that might require more of something more like what Dom has done, or something really expensive. (Nothing against bigger brakes, a la C6 Z06 or the like. But, for my driving style - which is mostly within the parameters of what we experienced on the Mountain Run, I found the combination of the HPS pads on the stock ZR-1 calipers and discs to be more than adequate. Your (and others) mileage may vary!)
Paul
90 #1202
Sans secondaries
Old 06-25-2014   #7
GSJoe
Hey Paul, I know I'm chiming in a month late for this thread, but I just saw it for the first time. I want to say I had the same experience with my '90 and fully agree with you. After trying several makes of pads--none of which satisfied me just for street use--someone on this forum suggested trying the Hawk pads. I did and was pleasantly surprised at the tremendous improvement in stopping power over stock pads and several after-market makes. I had already purchased A-molds for my car in preparation for the upgrade to C5 calipers and rotors, but the Hawks ended that plan and expense. They really are good!
GSJoe is offline   Reply With Quote
Old 06-25-2014   #8
Yes, and in addition to the Mountain Run (3 days of twisties), braking from over 140 mph last Sunday I found a very gentle touch was all that was needed to haul 'er down quite easily! NO problems getting stopped - in fact sorta cruised steadily along at about 30 mph on my way to the turn-around at the end of the runway. However! They DO dust a bit. But, what the hell...its a small price to pay for what, as you said, might have been expected from a big brake upgrade.
I'm no longer in the market for bigger brakes either!
90 #1202
Sans secondaries
Old 06-25-2014   #9
PhillipsLT5
PhillipsLT5's Avatar
I installed HPS on stock system, a better feel for sure, increasing horsepower is great but we also need to increase stopping ability and that's not happening by losing weight
Old 06-25-2014   #10
Roadster
Roadster's Avatar
Anyone have the part#'s handy, or refer to the correct page for the pads...Tom
1974 LS4 454 Vert
1974 L-82 355 Vert.
