Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 05-15-2014   #1
4CamJon
Default Bose help needed
I just bought a 91 ZR-1 and the Bose radio has no sound but the tuner works. When I got the car the battery was dead. Could the radio be coded? I don't have any manuals for the car and I can't remember if they say "Code" on the display or not.
What is an easy way to trouble shoot the system?
Thanks,
Jon
4CamJon is offline   Reply With Quote
Old 05-15-2014   #2
Default Re: Bose help needed
Thanks,
Jon
Speaker Amps may need replacement. Bose Speaker Amps
Old 05-27-2014   #3
4CamJon
So in your post on the amps it says 95-99 Maxima speaker amps. Does it matter which model Maxima that is or do they all have the Bose speakers? I see that it has to be a specific amp number or they don't work.
Thanks for your help!
Old 05-27-2014   #4
I did not know there was different 95-99 maximas
This is what you are looking for. You will need the white connector on a pigtail also.
You should be able to get these amps for $5-$7 at pull your parts wrecking yards.
Old 05-27-2014   #5
4CamJon
They had a GXE and a SE model. If it is with the base radio that will help me when I call the salvage yards to see if I can find some.
Thanks again.
Old 05-28-2014   #6
4CamJon
I just looked at a 98 Maxima and it had Panasonic rear speakers with the factory radio so I am confused. I will keep looking.
Old 05-29-2014   #7
I guess 95 Nissan Maxima only then.......as I think I got them from 95 Nissan Maximas as I recall.....
The 95' Nissan Maxima Speaker with Amps look like this.....
The 95' Nissan Maxima Amps are direct replacements for Bose Amps in the ZR-1.
The only issue is the little white connector on the Nissan Amps is much more usable than the original soldered connection (1990 ZR-1s) on Bose Amps. Pigtails for Nissan Amps are available.
95' Nissan Maxima Front Speakers..................................95' Nissan Maxima Rear Speakers
See Bose Speaker Amp Options TIPS
Old 06-01-2014   #8
95 LT5
95 LT5's Avatar
1996 Maxima also. Just picked up 4 today. Thanks for the help on the solutions page.
'95 ZR-1
RED/GRAY
#261
'95 ZR-1
BLK/BLK
#268
'89 6-Spd
FX-3,Z51
BLK/BLK
95 LT5 is offline   Reply With Quote
Old 06-01-2014   #9
Great Information....I am assuming those amps were SIGMA 975s Front and Rear?
thanks
Old 06-01-2014   #10
4CamJon
I went and looked in a 95 Maxima and it also had Panasonic rear speakers with the factory radio. Is there an optional Bose stereo package for the Maxima's that is some models?
