05-11-2014 | #1 |
testing the ALCL. poor cold start running
What are the pins and their location on the ALCL to test for trouble codes? I am referring to the paper clip method. If I remember correctly they are the slots in the upper right corner but I am may be wrong.
I started my z yesterday and not more than 100 feet later the car began to stumble and almost cut off. After warming up it went away and began to drive fine except for a slight bog in 2nd gear under load. The car has about 68K on the clock and there seem to be a lot of original parts on the car. I have replaced the coils and wires. The prior owner installed new FIC injectors that are ethanol compliant. Thanks ahead of time!
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 05-11-2014 at 10:43 PM. |
05-11-2014 | #2 |
Re: testing the ALCL. poor cold start running
Did you get a Set light? If not, you may not see any codes
05-11-2014 | #3 |
No SES light.
05-11-2014 | #4 | |
Not being too familiar with the LT5, I would assume that you start from the beginning. Such as, fuel delivery, spark (ignition), grounds, etc.,etc. If the engine doesn't have a code, you would need to go through each system to narrow down the source of the problem....JMO
05-11-2014 | #5 |
The ZR-1 is an OBD-1 car. Pins and pulling codes is the same across all vehicles.
05-11-2014 | #6 |
I assume they are the top two right pin holes, pin A & B?
FEDCBA G
05-11-2014 | #7 |
Never mind, I just tested the ALCL and it threw no codes.
05-12-2014 | #8 |
I am beginning to think I may have a fuel problem
Is there anything specific about the ZR-1 fuel system any care to share? In particular how the fuel pumps work? I just connected a fuel pressure gauge and it would not move past 20 psi at idle and it bounced maybe to 25 psi while driving the car. I think either my fuel filter is clogged or the problem lies within the fuel pumps and or assembly. I put the gauge on my daily driver Malibu and it held 30 psi so I know the gauge is working. Is this normal fuel pressure for the LT-5?
05-12-2014 | #9 | |
The FP should be in the 43+# range. If you haven't changed the filter, you should do it anyway. You may want to check the pumps. If they are original, it can also be an issue w the plastic clamps in the tank. They may be loose enough so that they lose pressure sort of like a leaky blood vessel. If not that, could be time to change the pumps
05-12-2014 | #10 | |
