Old 05-03-2014   #1
DarkAngel
DarkAngel's Avatar
Default Throttle body coolant issue
Hello everyone,
Ive replaced recently my throttle body with a custom one from Carter
I also bought a new gasket from jerry
And unfortunately, now there is a coolant leak from it
Do u ever had this kind of problem ?
DarkAngel is offline   Reply With Quote
Old 05-03-2014   #2
Default Re: Throttle body coolant issue
I like that Carter cover. Nice addition.
Did you put sealant on the gasket ? Clean off all old gasket material ?
I would just bypass the coolant line.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-03-2014   #3
PhillipsLT5
PhillipsLT5's Avatar
FU has the right idea
Old 05-03-2014   #4
DarkAngel
DarkAngel's Avatar
clean off gasket material yes
put sealant on the gasket ... no
I thought the gasket would be enough
Old 05-03-2014   #5
Franke
I have that problem and I will do what FU says to bypass the coolant to the TB. I ordered a bypass pipe from Marc Haibeck and it can be done without removing the plenum. Marc indicates no issues down to 20 degrees and 98% humidity. The coolant leak causes the paint around the plate to deteriorate.
Old 05-04-2014   #6
Default Throttle body coolant Blocking
See item #4 LT5 Eliminated Systems
On this LT5....For the purest I Eliminated TB Coolant by plugging the single port in each Injector Housing Only (as well as return line to Coolant Reservoir is blocked). That way you get the full advantage of Plenum Removal without having to mess with coolant in any way (On three other ZR-1s, TB Coolant is completely blocked with ALL associated lines removed)
You will see a spice in the line returning to the Coolant Reservoir which contains a plug so coolant cannot get into the TB from the Injector Housing but cannot get the the TB from the Coolant Reservoir either.
