05-01-2014 | #1 |
Coolant Temp Sensor
I have code 14 at startup when engine is cold. I believe I need a new coolant sensor. Where is it? On water pump or accessible?
[SIGPIC][/SIGPIC]1991 #0663 |
05-01-2014 | #2 |
Re: Coolant Temp Sensor
05-01-2014 | #3 | |
Thank you, Not too bad since the plenum is coming off soon anyway.
