04-30-2014 | #1 |
Couldn't get the 94 in gear......
On the weekends I shift the 94 and the 82 in the garage, so it is easier to get into the 94 and go. We went out on Sunday, and I have noticed the past two times, that the trans is hard to shift when cold, but felt better as the Z warmed-up. So not thinking to much about it (yea right!!!) I go to move the Vettes on Monday to get them in their spots for the week, and I can't get the 94 into gear, any gear...... So I stayed relaxed and finally it went into 2nd gear. Since my garage floor is at a very slight slope, it was enough to move up a few feet and then let it roll back until I got it over on the other side of the garage. That was close....
So I lift the hood, move the ECM and check the Clutch cylinder and besides what's in there being very dark, the fluid was very low. So I add some fluid and pump the clutch pedal about 15 times, and with the engine off, it now is going into gear easier than before. Did a search on the forum and learned alot about the system. Need to check for leaks, possibly change out the fluid and see if there is a leak, or just remove and send it out for a rebuild from one of the vendors mentioned in the thread that I was reading. Also doesn't seem hard to remove or install. This may be the next job for the Z......
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 05-07-2014 at 04:27 PM. |
04-30-2014 | #2 |
Re: Couldm't get the 94 in gear......
Tom,
I'd make sure the clutch fluid is or was changed... Also change out the transmission fluid too, either one could cause the symptoms. Do you have a list of maintenance records? David |
04-30-2014 | #3 |
Actually the '90 self-bleeds, and when you pump the clutch, it will bleed out the reservoir. In that respect, it's actually one of the easiest clutches I've ever bled. That said, my slave bit the bullet - even after cleaning out the black sludge, it didn't last a day before I saw drips and the pedal flopped to the floor.
I just got a rebuilt unit from Jim @ Power Torque Systems, and I'll be installing it tomorrow. He recommended priming the slave with fluid prior to installation, making bleeding much quicker. As long as I can get past the CAGS, it shouldn't be too tough. Interesting factoid, Jim told me the 89-90 slaves used a breakaway bleeder valve, intentionally torqued off at the factory - that's what is under that rubber cap. Really Chevy? I swear I'm finding all sorts of things that confirm they never intended these cars to be serviced.
Mark '90 ZR-1 #1322 Daily Driver, 64k and counting Black/Gray [IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG] |
05-01-2014 | #4 | |
I don't see that as condescending, he is highlighting a fact isn't he? Is Cliff attacking you? Absolutely not. I think you are reading it wrong... Cliff even deleted the posts because you were upset about it. David |
05-01-2014 | #5 |
Cliff, what were your exact symptoms when your slave failed? My Challenge car is ailing in that respect, so I'd just like to compare notes.
Those that have been around here a while know that this "style" is just your way of communicating. Not condescending at all....at least not to me because I understand the flavor in which it is meant and conveyed. You are always perceived by myself as helpful. I also applaud Dynomite for deleting the posts in question. He did so for everyone's benefit. This is a perfect example of how we all strive to respect each other and exchange information. 4Cam...I'm sincerely not criticizing anyone who takes it differently at all, either. Just listing my understanding of the bold red "style'". Thanks
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 05-01-2014 at 01:18 PM. |
05-01-2014 | #6 |
let's play nice everyone.
05-01-2014 | #7 |
Mark your missreading this. Cliff is just trying to highlight a solution. Cliff is a very nice and helpful guy
05-01-2014 | #8 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-01-2014 at 01:37 PM. |
05-01-2014 | #9 |
Dave (WV ZR-) is a wealth of knowledge for part numbers and this type of stuff. Always enjoy reading when he contributes these things. Thanks!!!!
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 05-01-2014 at 03:45 PM. |
05-01-2014 | #10 | |
No records as of yet, got in contack with another previous owner, so we will see where that goes..... Tom
