![]() Join Date: Dec 2003
http://jerrysgaskets.com/store2/root...ee9a2385954ce4
We have finally expanded our listing of Ram Clutches for the ZR-1 and added 2 new aluminum billet flywheels, with some features not offered by any other manufacturers, features that I believe, offer better and more options, relative to a ZR-1 owners preferences and needs. The new flywheels are custom made exclusively for Jerry's Gaskets, PN's 10202537 & 10202538. Many different clutch options at prices competitive with Summit & Jegs. We will be adding more, stock replacement pull release style clutches, as well as a hydraulic push-release style, compatible with the dual mass flywheel and our new aluminum flywheels mentioned above. Your feedback is welcome and appreciated.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 04-22-2014 at 12:25 PM. |
If you just need to replace the disc, with the dual mass flywheel & stock pressure plate, you can use either one of these clutch discs.
http://jerrysgaskets.com/store2/root...roducts_id=874 or http://jerrysgaskets.com/store2/root...roducts_id=886
![]() Join Date: Aug 2006
Fantastic! I know I will be going down this road sooner or later.
Thank you for helping us keep our Zs running. |
And thank you for doing a *great* job of laying out the options in a sensible fashion.
I keep wondering though how the pedal effort is with the Ram stuff especially converting push/pull, which new for this year my rules package will allow! Cheers, - Jeff |
Scott, one of our WAZOO gang, had Mrac install Ram clutch. I believe some mods were made to Ram kit to work with OEM dual mass flywheel.
His thread indicates Ram set up feels as good, if not better then, OEM. http://www.zr1.net/forum/showthread.php?t=22736 |
![]() Join Date: Jul 2007
Nice Jerry, glad to see some more options
