04-18-2014 | #1 |
Alternator going bad?
What are some of the signs?
I noticed today when I get on it at about the 5K RPM the voltage meter on the dash starts to drop (enough to see it move) not sure what voltage it drops to.. otherwise all seems fine.. Do I need to get a replacement again?
04-18-2014 | #2 |
Re: Alternator going bad?
volts being all over is a definite sign its going, check your batter terminals first make sure its tight
04-18-2014 | #3 |
or might be all of the high tech gadgets you are running in your car zapping the power
04-18-2014 | #4 |
Sure if it all over the place, but the Needle stay put until the RPMs climb past 4K, then the voltages fall, as soon as the RPMs drop it is fine.. I doubt the 12-5v ps I added is causing the issue.. Many people are using it.. Guess I will buy an Alternator to be safe
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 04-18-2014 at 04:17 PM. |
04-18-2014 | #5 | |
[SIGPIC][/SIGPIC]1991 #0663 |
04-18-2014 | #6 |
Yeah but having a spare is always a good thing.. might buy a higher output one that was shown on here awhile back
04-18-2014 | #7 |
When mine went out of my 9500, 95, the battery light came on the display eventually.
Evidently, the car had not had a battery tender on it for some time. It does now, always.
04-18-2014 | #8 |
You want to check the complete electrical "on the car" using a "Carbon Pile" load tester and a DMM. That's the only way to actually evaluate the system and it should be done before doing any alternator/generator OR starter replacement.
04-18-2014 | #9 |
OK, get down to 11 volts when at 5k rpm
Below that rpm it is high 12s, I will data log to a file next time
04-19-2014 | #10 |
Battery V should be at 14.5v or so at idle if alternator is doing it's thing.
