Old 04-17-2014   #1
Default Fuel Tank Pressure
Just a quick ? On removal of the fuel cap on the 93 I get a lot of pressure release. Normal? I ask as I get very little on the 91. Do I have an issue with the evap system? Would to much pressure cause a rich idle?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-17-2014   #2
mike100
Default Re: Fuel Tank Pressure
It only takes about 3-4 seconds to vent the fuel tank pressure through the purge solenoid so it won't enrichen the idle for all practical purposes. If you still have a stock exhaust, you can sometimes hear the hiss if things are just right.
I would have to review info in the FSM, but I don't think the purge lasts very long, just during the engine start-up to suck the vapors out of the charcoal canister and the top of the tank. I think it may turn on during lean cruise- or maybe a small duty cycle on/off as a controlled vacuum leak, but I can't say for sure on the obd1 GM cars, but some of the emissions stuff is pretty interesting.
Old 04-17-2014   #3
When I remove to fuel cap regardless of fuel level after a drive I get a noticeable whoosh of air. Just want to be sure the system is working properly.
Steve
1990 Red/Red #1473
Old 04-17-2014   #4
fletchusmc
My 95 has a lot of pressure as well when I remove the fuel cap, interested to see if this means anything?
fletchusmc is offline   Reply With Quote
Old 04-17-2014   #5
scottfab
scottfab's Avatar
only thing I could find on gas cap pressure testing wast this from the EPA. It seems to allow for a certain amount of leakage.
Are people seeing a true pressure build up OR a vacuum build up?
Gas Cap Test
(1) Cap Installation. The fuel cap, or caps, shall be removed from the fuel inlet(s) and installed on
a portable or bench test rig using the adapter appropriate for the gas cap as specified in
§85.2227(d)(1)(ii).
(2) Leak Measurement. The gas cap leak rate shall be measured and compared against a 60 cc/min
at 30 in. WC flow standard. Pressure decay measurement using instruments with a 1 liter head
space shall be made from an initial pressure of 28 in. WC and be compared against a loss of 6
in. WC in 10 seconds.
(3) Cap Replacement. The fuel cap(s) shall be replaced on the fuel inlet and tightened
appropriately.
Scott
Old 04-17-2014   #6
That is a good question Scott,
Found the same info. There are a few posts over on the other site but no definitive answer.
Steve
1990 Red/Red #1473
Old 04-17-2014   #7
Schrade
Gas Cap Test
§85.2227(d)(1)(ii).
appropriately.
Anytime I have my front end up on ramps, and air temp increases 15' - 20' F, I start smelling strong gas near cannister while wrenching. I go to the back, loosen the cap, and A LOT of vapors release.
Makes me think that tank angle, and gaseous pressure increase, forces fuel through the EVAP line, instead of just vapors... (I keep the tank full too).
On LT1 top end rebuild, I was greeted on second day by steady drip of fuel from disconnected lines, whereas it was NOT dripping shortly after dis-connecting the first day.
Old 04-17-2014   #8
Schrade
3 - 4 seconds...
What if the purge of vapors was CONTINOUS?
That's something I always thought on, when I spent $300.00+ / day, keeping a small delivery fleet rolling (@ $1.79 / gal).
One night, I was talking about that with the Ops Manager, when the line hauler was late. He told a story about a friend who devised something like that with a carb'ed car late '70's, who then submitted it to one of the big 3.
He said shortly afterward, his friend disappeared. He said he got a letter from his friend several years later, from Canada, who was doing 'very well', after signing something, and then getting a big check...
Only some safety mechanism is necessary, to prevent a mis-fire from lighting up the tank...
Old 04-17-2014   #9
mike100
^^^ yes...and the carburetor that gets 100 mpg...
c'mon- think about it...if the car gets additional gas from the vent, the closed loop control will just lean out the fuel injection achieving stoich fuel mixture either way.
As far as the tank vapor vent...back in the old days it either went to the atmosphere or into your oil before they had PCV valves.
Old 04-17-2014   #10
Schrade
Layered fuel charge (called something, that I can't remember ATM) is old tech Mike; for cruising, air-to-fuel mix in EXCESS of 60:1 is possible.
Only NOx's in excess of EPA limits is preventing this now in 'rice' mills...
ed.:
It's called Stratified / Direct Injection (and that's still liquid-phase, not vapor-phase); no longer only in theory, but in practice, in some applications, that I cannot recall ATM here...
