Old 04-12-2014   #1
Default Power Antenna removal?
Has anyone removed the power antenna?
Any suggestions? I need to remove it to figure out why I get good reception then bad.. try to check the wiring as soon as I touch it the reception instantly improves, I would like to pull it out and see all the connections etc
thanks
Old 04-12-2014   #2
Kevin
Kevin's Avatar
Default Re: Power Antenna removal?
the motor is behind the DS rear wheel liner it's easy to take apart
Old 04-12-2014   #3
yeah I know where it is.. just curious if there are any tricks to taking it out
Old 04-13-2014   #4
mike100
I removed mine on my old 95 LT1 car and replaced it with a mini stubby antenna replacement. The antenna coaxial line is well inside the interior and you have to remove the top trim piece above the cargo shade and a fold some carpet back to find it if I recall well.
Old 04-13-2014   #5
WVZR-1
The coaxial and power connection is like Mike mentioned behind left rear trim. You might consider first checking the condition of the ground strap and it's connections at the antenna before removing. I'd likely consider this before complete removal. Do you have amps in the rear?
Old 04-13-2014   #6
How well does the stubby one work?
Old 04-13-2014   #7
I took mine out, if I recall pretty straight forward, a few small screws and it drops out.
Old 04-13-2014   #8
Blue Flame Restorations
It attaches to a bracket. Once you get to it, it comes off pretty easily. I agree, ground strap check.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-13-2014   #9
Do you have to remove the top nut by the mast? This is the one under the grommet where the antenna protrudes through the body or is that just the mast keeper nut.
Think I might have replace the assembly depends g if I find any bad connections
Old 04-13-2014   #10
Yes checked and tighten that, still could be the issue. I do have amps in the rear, but have had that set up in this and my last Verte and my last one never had an issue, it was an 89. I also have the ground plane kit, just cannot find the directions for it
