Old 10-04-2006   #1
ajaxajax2000
ajaxajax2000's Avatar
Default Max tire size?
I'm changing wheels on my Z and I would like to have some more rubber than the original low profiles (275/40, 315/35) which if I do my math right has a profile hight of 110 mm. My new wheels will be 9,5x17" and 11x17". But how high a tire is there room for? On the picture below it sure looks like the tires are much higher than 110 mm. Don't know what wheel size it is though.
Can anyone advise on this, please?
Peter
'92 ZR-1, black on black, mostly stock (sold)
ajaxajax2000 is offline   Reply With Quote
Old 10-04-2006   #2
Kevin
Kevin's Avatar
Default Re: Max tire size?
you can run a 335/30 (or 35 i'm not sure) 17 rear tire on the stock rime. the car you posted is fastlanes drag car. That car has been modded to hell and back so anything that is stuck under that car won't fit on yours. Why do you want to stick a taller, if I'm reading this correctly, tire on your car?
Old 10-04-2006   #3
ajaxajax2000
Kevin, no other reason than that I think it looks cool. (Plus it would give a softer ride.) Been to my dealer today and the subject is dead. The only tire awailable seems to be 335/35/17 rear and 275/40/17 front which I ordered (Michelin Pilot Sport PS2).
Peter
Old 10-04-2006   #4
Kevin
Kevin's Avatar
Sounds like as good of a reason as any. Enjoy the new tires
Old 10-04-2006   #5
ajaxajax2000
Certainly will! I'll get the wheels and tires in about 4 weeks. Winter is closing in here in Sweden so I'll spend the rest of this season burning out my old tires. Come spring my Z will role out on brand new wheels!
Peter
