Old 03-17-2014   #1
Default Photo request
Can anyone send me a photo of their engine bay for reference? In particular I would like a photo showing the space between the radiator shroud and the motor as a reference (having the frame bumper horns tweaked on Saturday).
Thanks in advance!
Email: Written to thwart grazing. Use "@" and (.)
traineng (at) hughes (dot) net
Paul.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-17-2014   #2
1990 quasar blue
Default Re: Photo request
I sent you one that I had on my phone. My car is in storage so it's the best I have. Hope it helps.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 03-17-2014   #3
mike100
What useful pic I have on my photobucket acct is limited to this single picture, but I may have a top down picture in the archives on the home pc.
Old 03-17-2014   #4
scottfab
scottfab's Avatar
I sent along three at you email address.
Here are links to large format files just in case you need to zoom in on some location..
http://zr1.net/forum/album.php?album...pictureid=2495
http://zr1.net/forum/album.php?album...pictureid=2494
http://zr1.net/forum/album.php?album...pictureid=2493
http://zr1.net/forum/album.php?album...pictureid=2492
http://zr1.net/forum/album.php?album...pictureid=2491
Scott
Old 03-18-2014   #5
Thank y'all that sent the "cards n letters" (pix!)! I realize I could have been a little over-sensitive to the amount (or lack there of) space between the shroud and the motor - mostly concerned about the hoses, etc that are sandwiched in between. And, apparently, from the pix, it was for good reason. But! it isn't nearly as bad as I thought.
The pix have/will help immensely on Saturday!! Thanks everyone again!
Paul.
90 #1202
Sans secondaries
Old 03-18-2014   #6
scottfab
scottfab's Avatar
Paul.
Hope all works out on the tweaking.
BTW on the mail address term for obscuring the address from "grazing". I've always referred to it as "scraping" for addresses.
Scott
Old 03-18-2014   #7
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 03-18-2014   #8
scottfab
scottfab's Avatar
Originally Posted by We Gone View Post
Must be that LT5 delete model.
Scott
Old 03-19-2014   #9
My big concern was the horns might have been bent back and upward slightly, pushing the radiator back, sandwiching the A/C canister and the various plumbing between the shroud and the motor.
Thanks to the photos y'all sent me (thank heaven for this FORUM!), what I thought was some smooshing in that area was actually about normal: I had it in my mind the A/C canister (for one example) was NOt tucked under the cross-over coolant pipe, as it IS (after all!).
Well, apparently, the 'fulcrum' point where the horns bent were in the general vicinity of the motor mounts. I believe the horns ARE STILL bent ever so slightly, due to all indications, but not so much as I initially thought, nor anywhere near enough to affect the radiator/motor space to any important degree.
So! The radiator/shroud etc, went together fine yesterday (Thanks, to Marc H for that tip on cutting a little corner modification to the shroud housing near one of the shroud's bolts).
It's good enough to drive to the frame shop on Saturday, but once I crawled under the front end - fitting the various radiators to their respective rubber mounts - it is obvious all the radiators are going to have to come out again, to replace the bottom half of the shroud UNLESS I can fab up a mount to replace one that holds some of the air dam pieces in place. (I hate kluged "fixes", but this one is out of site and would just replace a support tab.)
Making progress!
90 #1202
Sans secondaries
Old 03-19-2014   #10
scottfab
scottfab's Avatar
....snip...
Making progress!
And there in lies the key. Good to see.
Scott
