![]() Join Date: Nov 2013
I'm going to be running my Z for the first time in an SCCA solo event the end of the month. I've run my 87 a few times and had a blast. Any words of advice from any of you that may have run yours before?
![]() Join Date: Jul 2013
I'll be running mine this spring too. Long time solo-2 participant and I actually got to run a modified C4 once or twice, but the ZR-1 will be a first. I'll be happy to trade tips!
watch engine & oil temp
do not keep RPM at 5.5 to 6K or above for more than 30 secs |
![]() Join Date: May 2005
Do a search on overheating and thermostat functions. Do not run the car until you have read and understand how the radiator bypass system works and why GM installed it on the lt 5.
Tyler |
Thanks for the advice. Only have 1 event near here. I don't foresee any extended high rpm's as it's a fairly small course, usually about a minute in length. If you search YouTube for Caro-vettes will give you an idea of how it is laid out. With my 87 it's a bit long to stay in 1st the entire course. I think with it some 3.07 gears would help quite a bit with second gear. I've run it in BSP and kept swapping first and second place with a Saturn Sky Red line turbo. He was on stickier tires than my Sumitomo's. Running the ZR-1 in BS which right now also has my buddy's 93 and some Honda 2000's and Subaru STI entered. I'm running NT555's on the back and Pilot Sports on the front. I don't plan on getting deep into the autocross but for me just learning how it feels and what its limits are without killing too many cones is the definition of a really fun weekend!
![]() Join Date: Feb 2012
Don't forget the brakes!!!!!!!!
So I'm only 4 months behind on posting an update as to how this went! Had a blast as usual
![]() http://vid1342.photobucket.com/album...ps05aaf9aa.mp4 Last edited by fletchusmc; 07-17-2014 at 08:46 PM. Reason: video |
Thanks for sharing - looks like you had a blast. The ZR-1's are a lot of fun!
#9 |
C4's benefit hugely from an alignment with seemingly wacky specs - it's really the factory specs that are wacky (seemingly lawyer induced). I've posted my thoughts before LMK if you want to pursue, or search my posts.
Lowering also helps, as does tire footprint, springs (start w/z51), and the quick steering rack. The z51 front control arm bushings are much better too but pretty hard to find - once you have and use grip the stock zr-1 lca bushings won't last long. Don't know how I missed this post the first time around, I think I don't always make it into the General section! Glad you had fun, I never imagined there would be something that could make me glad to get up early in the AM ![]() Cheers, - Jeff |
#10 |
Looks like you had a great time! I took my daughter to her first autocross last weekend and she loved it, and is shopping Miatas now. I didn't run the Z this time (took the 308 instead), but the next event is in early August and I'll run it then. Should be a blast.
