Old 09-30-2006   #1
3504v
3504v's Avatar
Default Need help with my 91.
I was pulling my 91 into the garage and decided to check my average MPG. Pushed the button and all I got was SYS flashing not only that but the power switch is not working and the temp control unit is out, no lights no temp no nothing. Checked the fuses they seem fine, what kind of gremlin is messing with my Z now.
3504v is offline   Reply With Quote
Old 09-30-2006   #2
Tyler Townsley
Default Re: Need help with my 91.
Sys is usually associated with the battery. Either it has/is going bad or the connection is going bad.
Tyler
Old 10-01-2006   #3
3504v
3504v's Avatar
Tyler
Battery is 6 months new, volts read normal, starts strong and lights are bright. Speedo, fuel gauge are fine, but the fuel info stays on INST and reads 0 at all times. When I try to change to average, range or trip it flashes SYS. Odometer works fine also.
Old 10-03-2006   #4
guinnessdood
guinnessdood's Avatar
Check the actual battery voltage. If the voltage is down a little...the SYS light will flash...once the charge is restored it usually goes away. I suspect it's a common problem among ZR-1s that are not driven a lot...like mine. I had it too on the way to Vegas last month...it went away once I got a good charge on the batery.
guinnessdood is offline   Reply With Quote
Old 10-03-2006   #5
3504v
3504v's Avatar
But would that also cause the temp control and full power to go out? Seems like a hell of a coincidence for all three to stop working at once.
Old 10-03-2006   #6
guinnessdood
It can yes. Low voltage is a strange beast in itself...electronic things behave very strange when they are down on voltage...
Old 10-03-2006   #7
3504v
3504v's Avatar
I will check the battery and charging system, thanks.
