Old 09-29-2006   #1
2nd94Z
2nd94Z's Avatar
Default Power Window not working
D the drivers window does not work, passenger side works fine.
Following the manual, first check lead me to believe the switch was bad, disassembled it, cleaned and replaced, not the problem.
Bad motor, replaced assembly, problem sloved.
thanks for your help.
2nd94Z is offline   Reply With Quote
Old 09-29-2006   #2
ffvetteman
Default Re: Power Window not working
My first guess(and its just a guess at this point) is the power window switch.
ffvetteman is offline   Reply With Quote
Old 09-29-2006   #3
Artic93
Artic93's Avatar
might be a regulator?
jason
93 Artic #189
Artic93 is offline   Reply With Quote
Old 10-02-2006   #4
Tim
Had that happen to me too. I found a used one as that is a discontinued gm part # but before it got here i fixed the problem with some electronic cleaner sprayed into the switch and working it back and forth several times. With power off of course. Two treatments and no problem since. Let me know if you need a used switch.
THanks, Tim
Tim is offline   Reply With Quote
