02-09-2014 | #1 |
Code 23
I just removed the secondaries. Took it out for a run and I an now getting a trouble code of 23 (MAT/INT AIR TEMP LOW). I am following the steps in the FSM, and it says to 'Disconnect Sensor'. Where is that sensor?
Thanks Chris
91 ZR-1 Red on Red #922 |
02-09-2014 | #2 |
Re: Code 23
Never mind. Found it. It helps when you plug everything back in.
