Old 01-31-2014   #1
Default Upcoming project
3/8th flat steel, drilled out for the plenum
Old 01-31-2014   #2
tccrab
tccrab's Avatar
Default Re: Upcoming project
Hmmm..... you're turning your LT5 into a 4 cylinder?
'Crabs
Old 01-31-2014   #3
Blue Flame Restorations
rut, row...
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-31-2014   #4
Lee,
I think it's gonna run rich.
Old 01-31-2014   #5
Schrade
Whatcha' pluggin' in there Mr L? Riser?
Torque boost? How much?
Good snappics there; keep 'em comin' here.............
Old 01-31-2014   #6
I am going to experiment with plenum volume....LT-5s plenum chokes it a higher RPM. Also the ceiling shrouds the runner...I will be adding 1" to the top and 1" to the bottom
Old 02-01-2014   #7
Schrade
Lee,
Why do you say it might run rich there Dom? With a riser under the plenum?
It will boost low-end torque - correct?
What else is in the mill?
Old 02-01-2014   #8
he is joking about being rich(if I put the plate on it would block air)
The plate is for the welding jig
Old 02-01-2014   #9
Schrade
Bring snappics there Mr L; I wanna' see this here..........
Old 02-01-2014   #10
cvette98pacecar
Looks like someone is going to be doing a little welding and does not want the plenum flange to warp.
