01-30-2014 | #1 |
Rear Tie Rod Ends
Another one of these Oh BTW while you're here...
My D/S tie rod end boot is destroyed. How "loose" should the tie rod end be? This one moves around pretty freely. Want to determine whether I just get replacement boot or replace the tie rod ends completely. p/S seems in good shape.
01-30-2014 | #2 | |
Re: Rear Tie Rod Ends
01-30-2014 | #3 |
So there should be some drag on the rod end then? This one moves around pretty easily. Do both sides? Did upper and lower ball joints last year on front end. However, haven't done front tie rod ends. May leave that for later.
01-31-2014 | #4 | |
Yes there should be some drag Dom. What you seem to describe was a lot of slop. I would suggest both sides as its a while you are there type of thing and considering the weather and that your interior is done go for it. I just replaced my passenger power set track two days ago because in a few weeks it will be creaping up to 100 again. (March) Yes I replaced my upper and lowers in the front two years ago as well with Moog as well as did the Prophane total energy urethane kit. I did the Tie rod ends as well. Remember you will need an alignment after any suspension work so its best to do everything you can before the thrust angle alignment because you have to do it evertytime you change something.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-31-2014 at 09:33 AM. |
