Old 01-15-2014   #1
TCurtner
Default HELP! Underdrive pulleys out there??
So, does anyone have experience with changing out the crank/water pump pulleys? Are there any replacement / aftermarket or alternatives/parts interchanges such that i could slow things down for (in particular) the water pump? Has anyone done any measuring out there?
Thomas (looking towards my own LT5 designation :-))
TCurtner is offline   Reply With Quote
Old 01-15-2014   #2
Default Re: HELP! Underdrive pulleys out there??
Talk to Pete or PM him I believe he has what you need. GC
Old 01-15-2014   #3
TCurtner
Pete? (being newer less experienced on forum)
Old 01-15-2014   #4
Pete is his online handle as well. So send a private message to Pete.
Old 01-15-2014   #5
Alternator and Water pump slowed by 10% with this underdrive pulley set....
Underdrive pulley set by Specialized Racing
Old 01-15-2014   #6
TCurtner
I'd like to get to 30% less on water pump, if possible. Have pulled A/C for track use. Am designing a workaround to bypass system that may work, but the waterpump is always an issue. May remove it and go electric, but would like to work in stepwise methodology - and try pulleys first. Will eventually publish my results on the forum for those interested. Anyone else have some sources for me? MUCH OBLIGED
Old 01-15-2014   #7
Electric water pump TIPS
Old 01-15-2014   #8
TCurtner
Yes, this is very close to where i was planning on mounting it - if the mechanical version doesn't work out. However, all that plumbing will be gone for me - you'll see soon enough.
