Old 01-14-2014   #1
TomZR1
Default Long cranking
I have 90 zr1 whenever i go to start it it takes a good 3 seconds is that normal,any info would be appreciated .
TomZR1 is offline   Reply With Quote
Old 01-14-2014   #2
Kevin
Kevin's Avatar
Default Re: Long cranking
perfectly normal.
Old 01-14-2014   #3
Vetman
Vetman's Avatar
yes, mine too. I believe the ECM controls the slow start. Normal
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 01-14-2014   #4
It has to find #1 before it starts
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-14-2014   #5
Blue Flame Restorations
My 91 sometime starts the exact moment you turn the key. All depends where compression is at. My Z is modded with cams as well.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-14-2014   #6
TomZR1
Thanks guys I feel a lot better
Old 01-14-2014   #7
Probably not a factor for you but a weaker battery will also cause longer cranking.
Old 01-14-2014   #8
3 seconds is perfect for both my 90' and 91'.......Now if I could get that quick start for my 1986 Silverado
Brett...what the hay is The ever-popular Ash Tray Relocation to Center Console for Car Wash Quarters mod
Is this another modification I should partake in
Old 01-14-2014   #9
edram454
edram454's Avatar
i have a 1990 also. your starting issue is perfectly normal. mine starts the same way every time. My car has no issue, throws no lights at any time.
Old 01-14-2014   #10
That was a well thought out modification to a repeatable issue....quarters kept falling all over my inner console area. Needed something to put them in. The rubber liner thingy is now in the console I like to think I'm a trend setter.
