Old 01-13-2014   #1
DarkAngel
DarkAngel's Avatar
Default Engine Smoke
Hello, it's me again
i have one question :
when i start my Z, the engine smoke for about 5mn to 10mn and then its ok
it happens often when the car stayed for a certain amount of time without moving
is it normal ?
here is a pic from where it comes (left part of the engine)
and a video
http://youtu.be/qG_aVo_l6C0
Thanks
DarkAngel is offline   Reply With Quote
Old 01-13-2014   #2
Default Re: Engine Smoke
How many miles on the car? How is the oil consumpton ?
Old 01-13-2014   #3
DarkAngel
DarkAngel's Avatar
it has 19000 miles
didn't notice abnormal oil consumption yet
i add a little sometimes
Old 01-13-2014   #4
There is a nut/stud that holds the header on that is leaking oil, needs to be resealed....only other issue might be cam sensor seal is leaking
Old 01-13-2014   #5
Header bolt or cam-cover? has to leaking on the exhaust manifold. Have you gotten up under it and done an inspection?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-13-2014   #6
DarkAngel
DarkAngel's Avatar
did a quick inspection and i didn't saw leak but i had nothing to lift the car to verify more closely
Old 01-13-2014   #7
cvette98pacecar
Lee can help you with the cam cover emblems.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 01-13-2014   #8
DarkAngel
DarkAngel's Avatar
i've ordered the emblems from jerry gaskets already
Old 01-13-2014   #9
The header stud leak can be deceiving it can run down the header....
Old 01-13-2014   #10
cvette98pacecar
Jerry is a great person. He is a big asset to the ZR-1 Net Registry.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
1998 Pace Car
