Old 01-03-2014   #1
Vetman
Vetman's Avatar
Default LT 5 stick on remove???
Is there any way to remove the stick on LT-5 big label on the cup holder door that you see on so many z's. IF not, are there new doors or perfect used doors out there one can purchase?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 01-03-2014   #2
Default Re: LT 5 stick on remove???
I've had good luck with 3M Adhesive Remover (most part stores) and a bit of mono-filament fishing line - for exterior badges, etc. The solvent left to stand a bit softens the glue, and the fishing line is stretched between both hands and like a wire saw, sawing back and forth while pulling the line under the badge does the job.
Jason at Vette2Vette is who I would contact about a spare door, if need be.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-03-2014   #3
scottfab
scottfab's Avatar
Here's how I did it:
1. turn the door so it is open and cover the surrounding dash etc
with towels.
2. spray a small amount of WD40 on the crack between the
lid and the metal sticker. Let it sit for a few minutes. WD40 destroys
the glue bond yet does not effect paint or plastic.
3. using a plastic comb, insert a few teeth in the crack in a
sawing action. Get it to open just ever so much. You're not
ready to pop it off, just open it a bit to spray in more WD40.
(fishing line here as mentioned is a good idea too)
4. go to step 2 and repeat.
5. eventually you'll work your way down and the metal sticker
will peel back and away.
6. clean WD40 with Windex or equivalent.
I did this on mine to replace the metal sticker.
Scott
Old 01-03-2014   #4
Vetman
Vetman's Avatar
thanks!! will give it a try. Amazing the answers one can get through this forum.
1990 Z # 2441
