Old 09-20-2006   #1
pavo_roddy
Default Any problems associated with.........??
Hi all,
Are there any problems associated with the timing chain? All I am asking is bascially what are the intervals like for changing them? I know that on the GM 3.4 DOHC you should change the timing chain every 50,000 or so, and since the engines were made just about the same time I was curious...
Part 2:
What kinda maintenance problems are there to owning an LT-5? Please note that the prices for parts; I KNOW are higher than any other SBC... Not trying to be mean, just clarifying things k.... Basically I would like to hear any or all problems that you all may have encountered while running with this engine..........
pavo_roddy is offline   Reply With Quote
Old 09-20-2006   #2
Default Re: Any problems associated with.........??
Hi, I think you might take a look at the zr1netregistry.com site as there is a good deal of info on maintenance and common issues. Also posted over there are the "fixes" for a lot of the common issues.
I'm no expert but I think that the chains' reliability issue was not a concern after Lotus got past the destructive durability testing. I could be wrong about that. I only know of one person that had a problem with the chains and that car was modded and raced.
