Old 12-15-2013   #1
cuisinartvette
Default Ported and polished Airhorn
I need a new camera
Good to see you all been awhile
Still playing with this stuff just been busy with the musclecars
One day another Z will show up.
Old 12-15-2013   #2
Default Re: Ported and polished Airhorn
that probably took acouple of minutes, nice!
Old 12-16-2013   #3
looks Familar
Old 12-16-2013   #4
bradley
if I can ask what steps did you take to get that awesome finish ???
bradley is offline   Reply With Quote
Old 12-16-2013   #5
cuisinartvette
GC yes this was your old one; What yrs does it fit?
Variety of tools used on the inside, outside large fine scotchbrite type wheel/buffs & diffferent compounds on the out;smaller hand tools for the tight spots.
Lotsa time like Lee said I know he knows;most guys wont touch these for a reason.
Hardest part is knowing when to stop lol. Fun stuff
Buffers are dangerous stuff. Grabbed an alt bracket from me yesterday and heard it ricocheting around the garage couldnt see it. Thank god it missed
Old 12-17-2013   #6
I think 90-92?
Old 12-27-2013   #7
cuisinartvette
This ones gone time to hunt down some more
Old 12-27-2013   #8
randy ransome
randy ransome's Avatar
I'm in the process of polishing mine. I've run into a bunch of sand pits from the casting on the outside, there on the inside also, but I'm not as concerned with those. Did yours have these pits and will they eventually sand out? I've sanded the outside a good bit but there are still some fine pits.
randy ransome is offline   Reply With Quote
Old 12-27-2013   #9
cuisinartvette
From doing other pieces probably varies
I got 0 pitting underneath some on the sides there is some up top.,
First few pits seem to buff out but if you go after all of them seems to uncover more. At a point you stop, buff and walk away it seems.
Trick is to do minimal sanding to get your finish then hit it with the buff.
Old 12-28-2013   #10
randy ransome
OK thanks that's kind of what I thought but now I can quit where I am and start buffing. This helps a bunch, thanks again.
