Dose anyone have a failed secondary actuator they woud want to donate so I could see if I can disect it and see if I can do a write up on rebuilding them so we dont have to rely on 20+ year old OEM parts on shelves it seems to be one of the rare specific parts on our cars. I figured if I found out how to rebuild our tensioners may as well tackle the next part.
Dave |
Dave
Yes. I've got one you are welcome to have Can you write up an article for the hotb? What's your address? I'll get it in the mail to you tomorrow Cheers David |
Zzzzr1 I'm not familiar with the term hotb. And thank you so much for the secondary
Dave |
Heart Of The Beast, newsletter
![]() Join Date: Oct 2004
The best explanation on how to install the secondary canister is provided by Jerry. Very appropriate here for backup information
![]() I have installed NEW canisters with the linkage arm straight contrary to what is/was normal (the original canisters were properly installed with the linkage arm at an angle). I have also modified the canister arm for an original installation so the arm did not contact the canister arm opening. Secondary Canister Installation TIPS Both installations seem to function without any interference. But for the record see Secondary Canister Installation FACTS TIPS
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-15-2013 at 11:52 AM. |
#9 |
![]() Join Date: Jul 2005
If you need another one, let me know. I have a couple.
By the way, when I redid my secondaries, I had one of the "new" actuators and "new" secondary vac solenoid fail within a month of install! I replaced the failed actuator with the good old one I removed, and bought a new solenoid. All has worked great for a couple years now. |
#10 |
I found the part under another part number and it was used as a egr component on another vehicle all i had to do is trim a little peice of plastic to allow the connector to work. When I get home Ill post the part number
https://www.facebook.com/photo.php?f...0&l=89904940bb https://www.facebook.com/photo.php?f...4&l=33ad5b6396 https://www.facebook.com/photo.php?f...0&l=8f262eb197 https://www.facebook.com/photo.php?f...1&l=fc469f6276 Dave Last edited by mgbrv8; 12-15-2013 at 05:30 PM. |
