Old 12-09-2013   #1
Default Looking for cutaway pic of Corsa Muffler
Been looking for a cutaway pic of a Corsa Muffler with the duel tips. I interested in how much flow actual goes to the second tip? I know one is a straight thru. All I find are cutaway's of single outlet. Any info. from you guys that have them would be great. I have a set of them on the way with the new black tips.
http://www.corsaperformance.com/view...4117BLK&cfg=38
Thanks.
Old 12-09-2013   #2
Default Re: Looking for cutaway pic of Corsa Muffler
I have some
EDIT:
Old 12-09-2013   #3
Thanks Jeff, I sent a message to Corsa and they replied all 4 tips are open, But one of them is more for the balance of the tone. They also would not release any information on the flow. From your pics this open/flow looks to be questionable.
Old 12-09-2013   #4
it is open but the photo is the crappy one in the middle..
are they a black chrome tip? and is the exhaust going to you or Marc for install?
Old 12-09-2013   #5
From there site (The black PVD material looks like black chrome)
http://www.pvdcoatings.org/l
http://www.corsaperformance.com/blacktips/
I will install them at home, Right now I have flowmasters with cats. I have to pass Ga. emissions first and one more time next year. Its not to much trouble just to swap them out. The flowmaster set up is welded so its one assembly I will do the same with the Corsa. Just want the extra HP the Corsa and no cats offer.
Old 12-10-2013   #6
The closed chamber of the Corsa is a Helmholz resonator that attenuates the resonance at a specific frequency. Our engines generate resonance spikes at about 1,800 and 3,400 rpm with a little also at about 2,400. The stock system uses the same technology. Corsa calls it quarter wave tuning. Essentially, the sound waves go into the closed chamber and based on its size and shape, sound waves of a particular frequency will cancel each other out. I forget which frequency the mufflers deal with, I think the 1,800 one, with the center resonator handling the 3,400 rpm resonance spike. By the time exhaust pressure gets to the muffler, the single pipe is more than enough to flow the gases without much, if any, back pressure. March Haibeck has done a fair amount of testing on exhaust system performance. --Bob
Old 12-10-2013   #7
Meanmyz
Meanmyz's Avatar
Thanks.
I also bought the Corsa's with their "Black Diamond" tips. I went through Summit Racing to get them. There weren't any deals out there on these mufflers on the internet, as Corsa built them per order.
When I got the mufflers, I took emery cloth and took special attention and time to scuff the muffler cans and outlets up to the tips. After properly cleaning and degreasing for any oils, I then painted the cans and outlets up to the tips black with Krylon high heat black.
Like you, I think these mufflers will look awesome on our cars.
Meanmyz is offline   Reply With Quote
Old 12-10-2013   #8
Meanmyz
Meanmyz's Avatar
Well, I'll be! From your link in the first post, I see that Corsa is advertising this setup now. They weren't when I ordered in August/September.
The Corsa rep said that they had made some special order that way in the past, so I wasn't the first one.
Corsa isn't allergic to money, so I am sure they'll go wherever there is a demand.
Old 12-10-2013   #9
Ordered mine thur Summit also I get free shipping as I can pick them up at the showroom its only 10 miles from my house. Great idea on painting the muffs black.
Thanks Steve
Old 12-10-2013   #10
Meanmyz
Meanmyz's Avatar
Thanks. That way it keeps the factory theme, but with the upgrade in performance.
