Old 12-04-2013   #1
Mitsumark
Default PCM Tach Signal
Do you guys know where and what wire I can tap into for the tach signal? I know installing an aftermarket tach can be tricky sometimes with DIS ignitions.Installing an Autometer tach in place of my stock unit if possible..Thanks..
Mitsumark is offline   Reply With Quote
Old 12-04-2013   #2
Default Re: PCM Tach Signal
On a1990 it is E1 on the C-100 connector located just to the left of your left toe as you drive the Z; look for the white wire.
Edit: might want to verify with your FSM to be sure it is the same on later model Zs.
