[IMG]
![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Just completed a power headlight motor rebuild on my 90. Purchased the kit from Mid America, and they only showed a bronze gear for the ‘90. I was concerned because mine had a plastic gear in it, but I figured I’d go for it. After taking the assembly off the car and disassembling the gear housing with the help of the guide from this forum it was time to remove the old destroyed plastic gear. The housing was full of ground up plastic and delrin. It was a bear to get out the old plastic gear as mine was stuck due to ground up plastic bits. I finally got it all out and cleaned up. Next was to install the new bronze gear with the three new delrin bushings onto the old shaft. It was so tight a fit that I had to press the parts together with my bench vise. I thought I was going to break something it was so tight, but it went together into a solid unit that dropped right back into the motor housing. I greased her up and reassembled the housing and reinstalled the headlight assembly. She tested out great with rapid up/down with no continued running after reaching full up/down positions. It was during this test that the drivers side started acting up, and now continues to run after reaching full up/down. Guess its time to order another rebuilt kit! Now it know better how to do the work, so it should be much easier next time. The “how to” on this forum was invaluable. I don’t think I would have attempted the task without it. Last edited by bamawrx; 11-27-2013 at 04:44 PM. |
Here is pic of nice new bronze gear installed...backwards. That was a self correcting error as it turned out.
[IMG] ![]() Anyone have a specific recommendation on a better headlight? I've looked at the C4 conversion kits that allow for HI bulbs and the Hella European headlights, but its dang near impossible to know what would be brighter. The stock lights are not up to the task. Last edited by bamawrx; 11-27-2013 at 05:08 PM. |
I went from sylvania silver stars to Hella H4 housings to HID projectors. To date satisfied. Suggest Hellas with the 120/85 bulbs. Any H4 build will fit those housings.
changed mine out to glasss bulbs. gave the plastic away. much more light now.
Added Pics.
![]() Join Date: May 2013
Good job. No more worries for awhile.
White lithium grease has worked well for me.
