Old 09-10-2006   #1
BROOMRIDER1991ZR1
BROOMRIDER1991ZR1's Avatar
Default NEED PROPER AIR PRESSURE SPECS FOR MY ZR1? HELP :(
I CAN'T SEEM TO FIND THE SPECS ON PROPER AIR PRESSURE FOR MY TIRES, CAN SOMEONE HELP!
BROOMRIDER1991ZR1 is offline   Reply With Quote
Old 09-10-2006   #2
yellowz
Default Re: NEED PROPER AIR PRESSURE SPECS FOR MY ZR1? HELP :(
air specs??does it not say on the tire what pressure is adequate??28-32lbs i believe
ps looking on my tires to see
peter
yellowz is offline   Reply With Quote
Old 09-11-2006   #3
tccrab
tccrab's Avatar
It will depend on the tires, but most street tires are 28-32.
Look on the sidewall of the tire, it will tell you.
TomC
'90ZR1 #792
Old 09-11-2006   #4
GM's PSI is on the door sticker, driver's door edge by the lock mechanism. 35 PSI on my 90. I used a bit less, say about 34 or 33 PSI but found that 35 seems to work better in the twisties after the my D3's get some heat in them.
Old 09-11-2006   #5
BROOMRIDER1991ZR1
THANKS FOR YOUR HELP!!!
Old 09-13-2006   #6
ZR1 MK
Proper is too much and the tires dont show pressures. Only max.
ZR1 MK is offline   Reply With Quote
