Old 10-10-2013   #1
KJL
Default Secondary Throttle blade linkage Lubrication
I noticed that the throttle blade linkage has ball in socket joints where the socket is plastic. What type of lube if any should be used at these locations?
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
