Old 10-10-2013   #1
KJL
Default Cam Upgrade Vs Emissions Inspections
We have emissions inspection requirements here in Atlanta GA. I have read that removing the secondary throttle plates can make it difficult to pass. How about a mild cam upgrade?
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 10-10-2013   #2
Default Re: Cam Upgrade Vs Emissions Inspections
With headers catback, highflow cats, Marc's prom I still have to put the stock prom back in to pass. Hopefully with the work Marc's doing on it now and a good tune I should be able to pass with out changing proms. I'll let you know in Dec.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-10-2013   #3
KJL
I forget, are you getting it cammed as well?
I have the typical mods i.e. porting, headers, high flow exhaust plus an unknown performance chip and passed without issue. I would love to bump up the cam just a tad but would not be happy if she cant pass emissions. I am spoiled working with out consequences for so many years on my 72. I bet you are losing sleep at night in anticipation....I would be!
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-10-2013   #4
Stock cams, full porting. 510hp package
http://zr1specialist.com/HAT%20Web/p...%20details.htm
Steve
1990 Red/Red #1473
Old 10-10-2013   #5
It depends on the sniffer pipe test vs the treadmill. If Atlanta is using the treadmill you will not pass. Sniffer maybe if everything Cats tune etc are running perfect. GC
Old 10-10-2013   #6
KJL
I forget, I think that as long it is OBD compliant, OBD I I believe, they just plug into that and do not run it on the drum.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-10-2013   #7
They drum in AZ......
Old 10-10-2013   #8
In Ga. OBD I you still have to do it on the drum, My wife's 95 is still a drum my 96 is plug & play, after 25 years or you turn 65 no worries.
Steve
1990 Red/Red #1473
Old 10-10-2013   #9
KJL
Thanks for the info, I know my 96 was plug and play which id OBD II. Sucks OBD I is not...
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-10-2013   #10
Franke
They drum in Colorado front range counties only!
